02-18-2025
04:32 PM
09:34 AM
Hi everyone I am a beginner photographer and I have been asked to take my schools track teams media day photos, I currently use the EOS Rebel T7 camera. Should I get another lens to take these photos or should my lens be fine?Also where should I get backdrop and lighting kits/set ups from?
02-21-2025 12:15 PM - edited 02-21-2025 12:17 PM
"they want photos of jumping over hurdles and things like that mainly doing just fun different poses"
OK, good, you mean you are able to do set-ups not actually event races or full action games? If that is the case and you are allowed to do the setup and have access to any point you want to shoot from I think what you have will work. One more thing is this outside in the daylight? That is best.
Here is how I do these and BTW, they are usually called 'promos'. Do you have a laptop? If yes tether the Rebel T7 to it so you can really tell if what you are shooting is what you and they want. Its far better than just the rather tiny LCD screen on the T7. You will need either Lightroom or one of the free Canon utilities like DPP4. To tether using Canon's DPP4 software, connect your Rebel to your laptop with a USB cable, open DPP4, and then navigate to the "Remote Shooting" function in DPP4. You can control your camera and settings and capture images directly to your computer screen.
Next make sure you use raw and not jpg. Use One Shot not Ai-servo. Start with P mode and sert ISO pretty high say 800 but maybe 1600 if needed. Using raw there really isn't any other in-camera setting you need as they can all be adjusted or edited in DPP4 but to get a good viewable image you may want to set WB to daylight. If P mode isn't doing the job try switching to Av mode and set your aperture yourself. Whatever don't go to any setting on the so-called auto side of the mode dial.
Let us know how it goes. EB
02-18-2025 05:05 PM
What lens do you have?
Just what kind of pictures do you want to take?
02-19-2025 10:30 AM
Your kit lens and photoshop should work well. If these are static photos you might want a tripod.
02-19-2025 10:32 AM
Your comment about sports photos makes me think this is for outdoor events, but your comment about lighting makes me think it might be indoor group shots. A little more information on that (including your current lens, as kvbarkley asks) will help us give you better advice.
02-19-2025 10:32 AM
Is something along this sample what you are after?
02-19-2025 11:18 AM
These types of sports photos aren't demanding of equipment since you likely aren't capturing fast action shots. So your current lens setup is probably fine.
B&H and Adorama have long been my sources for cameras and gear and they have plenty of lighting equipment (including used). But artificial lighting is a complex subject and quickly gets expensive so spend some time educating yourself on what you will need for this process.
Rodger
02-20-2025 09:46 AM
I have taken sports photos of X country and baseball. You might take photos of the events and experiment with settings. It's a learning experience...especially fun if the grandkids are involved.
02-20-2025 10:30 AM
It is impossible to recommend gear until we know what “media day” photos the OP needs to do or wants. So exactly what is it?
02-20-2025 02:31 PM
an EF-S 18-55mm lens
02-20-2025 02:33 PM
this is an indoor event, and there will be many group shots, I have an EF-S 18-55 mm lens
