04-20-2015 03:41 PM
Dear Friends,
I have Canon T4i and purchased Toshiba Wireless Flash Air 32GB card for my T4i. I am not able to find 'Eye-Fi' settings in my camera, tried seraching for it in P mode while setting Image setting as Raw+L. However, Eye-fi settings is nowhere to be found.
Can somebody please help me in enabling Hidden Eye-fi setting in T4i, so that I can use Toshiba wireless Flash card, which would going to let me share picture wirelessly with my Laptop/Mobile.
Thanks in advance 🙂
Cheers,
Rajneesh
04-22-2015 03:48 PM - edited 04-22-2015 03:51 PM
04-20-2015 06:29 PM
The Toshiba is not an Eye-Fi. It won't work through the camera menu.
You can use the Toshiba in ad-hoc mode, but it won't mesh with camera. You will have to ensure camera stays on while files are transferring by increasing auto off time. It will work fine ( Ihave used one) but it does require user interevention. The good thing about Eye-Fi is that it intergrates with camera and power control is automatic.
04-22-2015 01:00 AM
Eye-Fi is a specific brand. See: eyefi.com
I have an Eye-Fi card, but no longer use it. I found the transfers to be painfully slow. It wont transfer while you are using the camera. After you stop shooting and go idle for a few seconds, it will switch on the radio and start transmitting. JPEGs take several seconds each. RAW images take considerably longer. If you start shooting again before the transfers are complete it will abort the transfer, power off the radio, and wait until you go idle again before it resumes transfers.
I ultimately switched to a CamRanger. This is an external module (about the size of a mobile phone) which attaches via a wire to the USB port in the camera. It's able to control the camera remotely (via software for your computer, smartphone, or tablet) and it's transfers are faster.
04-22-2015 10:16 AM
I agree with Timm Campbell. It just isn't ready for prime time yet. Worse than poor!
04-22-2015 03:43 PM
Hello Friends,
Thanks for the valuable inputs. I might be able to use Toshiba Wireless SD card as an ad-hoc by inserting it into a laptop, but then I won't be having any mechanism to enable wi-fi in my T4i. I might give CamRanger a try, but prior to that I would like to share a video that showcases enabling hidden Eye-fi option in T4i. Below is the link to the video.
https://www.youtube.com/watch?v=OOkAanBW3y8
However, upon inserting Toshiba wireless flash SD card in my T4i, I am unable to find 'Eye Fi Settings' in any of the tabs.
I would be very greatful if someone can please enlighten me to enable this hidden feature in T4i.
Cheers,
Rajneesh
04-22-2015 04:29 PM
Hello John,
It was my mistake since I didn't search for the Flash Wifi signal. Now, I got connected to it from my macbook and can see the files on T4i 🙂
Surprisingly, it is working a bit faster for me, may be cause I am using 32 GB Flash air card.
Thanks everyone.
Cheers,
Rajneesh
09-10-2015 03:09 PM
09-10-2015 03:14 PM
Be aware that if you are not using an EyeFi card the camera doesn't recognize it (as you found out) and as a result the camera will shut off when it times out, regardless of whether or not the FlashAir has finished transmitting.
You will need to increase the time delay; just remenber if you go to Never be sure to switch back when transmission ends or your battery will die.
