11-19-2019 01:43 AM - edited 11-19-2019 01:43 AM
I have been trying to take some nighttime photos using the Manual settings in the usual way - increasing the aperture and decreasing the shutter speed until the little arrow tells me the exposure is correct. The camera appears to take an image but nothing results - any ideas?
11-19-2019 10:58 AM
" If camera can't focus it will not actuate the shutter."
Plus nighttime shots using the camera's metering system can confuse it. It could just be a really incorrect exposure.
Does the camera work in the normal daylight? If it does you need to learn more about proper exposure settings.
11-19-2019 08:29 AM
11-19-2019 08:33 AM
11-19-2019 09:49 AM
"until the little arrow tells me the exposure is correct."
"The camera appears to take an image but nothing results"
What do you mean by this - what is happening?
If you are in AF on the lens then camera may not be focusing because its too dark. If camera can't focus it will not actuate the shutter.
11-19-2019 10:58 AM
11-20-2019 12:22 AM
11-20-2019 09:24 AM
