04-10-2020 08:29 AM
04-10-2020 08:36 AM
"Any suggestions?"
Buy a real web cam or video camera, if you wish to use it for extended sessions. You cannot find documentation because you are using it in an undocumented manner.
04-10-2020 08:52 AM
I do not know if the work around described in the following thread will "work" with your camera. Seems like it should.
https://community.usa.canon.com/t5/EOS/M50-auto-power-s-off-even-when-disabled/td-p/250454
Again, I do not recommend using your camera in the mannner. It is likely to overheat, and possibly damage itself. If the temperature sensors on the image sensor detect that it is beginning to overheat, the camera will shut down.
However, if the circuit boards begin to overheat, there is no heat sensor inside of the camera body to shut the camera down.
04-10-2020 10:37 AM
@MissMasque wrote:
I'm having an issue using my Rebel T6 as a webcam. It lags so bad and it auto shuts off. I set it to never shut off but it still does after 30 minutes. I am using the webcam with skype, zoom and discord and it lags so bad. I cannot find in the camera settings on the computer or camera how to make it stop. Any suggestions?
In addition to the cautions that Waddizzle has raised, you should understand that you will never overcome the problem of video recording shutting off after 30 minutes. Canon programs it to work that way deliberately, to keep the camera from being taxed, in certain countries, as a video camera.
04-10-2020 10:42 AM
@RobertTheFat wrote:
@MissMasque wrote:
I'm having an issue using my Rebel T6 as a webcam. It lags so bad and it auto shuts off. I set it to never shut off but it still does after 30 minutes. I am using the webcam with skype, zoom and discord and it lags so bad. I cannot find in the camera settings on the computer or camera how to make it stop. Any suggestions?In addition to the cautions that Waddizzle has raised, you should understand that you will never overcome the problem of video recording shutting off after 30 minutes. Canon programs it to work that way deliberately, to keep the camera from being taxed, in certain countries, as a video camera.
Apparently, the trick is to use the EOS Utility to put the camera into Live View mode, and then connect to the HDMI output. It seems some cameras can stay in Remote Shooting mode like that indefinitely.
04-10-2020 10:43 AM
I am not sure the thirty minute rule applies since they are not recording on the camera.
04-10-2020 11:17 AM
@kvbarkley wrote:I am not sure the thirty minute rule applies since they are not recording on the camera.
Exactly.
04-10-2020 02:30 PM
04-10-2020 03:22 PM
@MissMasque wrote:
There is a setting to turn off the auto shut off but it doesn't work, it shuts off anyway.
It might be overheating and shutting itself down. How long does it stay on before turns off? Don't know? Find out.
08-20-2020 07:45 PM
