03-21-2024 03:35 PM - last edited on 04-11-2024 09:54 AM by Danny
HI
How do i insert an sd card into my canon rebel xti
03-21-2024 05:07 PM - edited 03-21-2024 05:08 PM
Molly,
Canon has put out a couple of instructional pages on how to install and remove cards into your camera.
Here's one:
https://support.usa.canon.com/kb/index?page=content&id=ART174108
I don't imagine the steps are too much different between the XT and the XTi
Steve Thomas
03-21-2024 05:27 PM
Well, XTi (like the XT) require a *CF* card, not an *SD*, so there is no "SD" slot. Here is how to insert a CF card:
03-21-2024 09:20 PM - edited 03-21-2024 09:20 PM
As my colleague alluded to, your camera will not take an SD card.
You need to get a CF Type II card - note: NOT a CF Express card. These CF cards are quite old technology and not as common as they used to be. Be sure to get them from a reputable source, as there are lots of counterfeit cards available via the web. Brands like SanDisk, Lexar and Kingston should be good.
I would not get a CF card in excess of 16GB to avoid issues with the camera's file system - your file sizes are much smaller than more modern cameras, so you don't need massive cards.
04-09-2024 03:08 PM
Which usb should i purchase to view my images on my computer?
04-09-2024 03:30 PM
Molly,
Your manual recommends that you use Interface Cable IFC-400PCU.
I have always had success using the USB cables that Canon itself recommends. You can buy them direct from Canon.
If you don't have a User Manual for your Xti, you can find an online copy here:
https://www.manualslib.com/manual/991136/Canon-Eos-Rebel-Xti.html#manual
see p. 3. page 107 has instructions on how to plug it in.
Steve Thomas
04-11-2024 02:28 AM
The Canon cable your manual recommends, which came with the camera when new, is a standard USB A -to-Mini B cable. Generic ones are available everywhere that has cables . . . office supply stores, drugstores, computer stores, on and on. If your computer has something other than a wide rectangular USB A port, you need that connector-to-Mini B.
04-09-2024 03:20 PM
Just search your favorite site for "CF card reader"
Depending on your computer, you might want to get one with the oval USB-C rather than the square USB-A.
04-09-2024 11:10 PM
B&H Photo offers some full size SD to CF card adapters, but I've never had occasion to use one. Hopefully you can readily find a smaller capacity CF card. Even smaller capacity full size SD cards are getting hard to find. Your XTi will probably scoff at any of the newer, bigger cards.
04-11-2024 02:20 AM
The SD-to-CF adapters can't work in a camera. The SD card sticks out the side of the adapter. You can't put it in the camera with the SD card in it.
