08-17-2022
07:52 PM
08:40 AM
Can anyone help? I am rather new to photography I have a rebel T7 and have been doing alot of nature, wildlife and astro photography. I have been shooting in RAW mode when I try to enlarge the pictures it tells me "low image quality" but it looks fantastic on the computer any suggestions on what I am doing wrong or how to fix it?
08-19-2022 01:10 PM
I can understand your challenges. Is there any way you can send the file to such a printing agency electronically? They can then examine the file and let you know if they think it will print OK. They might even be able to do that and ship the print to you. Since COVID, most companies can do remote sales and service.
If this resolves your issue, then please mark my solution as a resolution, so others will not continue to try to solve it. Good luck
08-17-2022 07:57 PM
To be honest, we are lacking a lot of information.
Perhaps post a couple of images, along with the settings for them: such as lens, focal length, shutter speed, and ISO values.
What program are you using when you are getting this message about low quality? Are you viewing the RAW image or a JPG image within that program?
If you look at the first menu item on your camera's menu there is an item for Image quality, what settings is it showing?
08-17-2022 08:16 PM
I am shooting most everything in raw but it also takes a jpeg at the same time for my night shots I have been shooting in manual 20" F2.8 ISO 3200 photos look good on the computer but anything over 8x10 and I get a low image quality warning For my day shots I have mostly given up on trying to shoot in manual and have been using auto still get the low image quality on anything over 8x10 I kinda live in the middle of nowhere so the only place I can have photos printed is wallmart probably not the best place but my only option
08-17-2022 08:24 PM - edited 08-17-2022 08:36 PM
OK, thanks for that. How about the resolutions settings for your camera? As mentioned, can you please advise what the resolution settings are on your camera: Menu, first tab, first page, first item. Thus:
Are you significantly cropping your images before printing?
What printer and printer settings are you using, particularly resolution?
08-17-2022 08:37 PM
I have been using the raw + L as that gives me 2 copies of each photo. As far a printer settings go I don't beleive those are adjustable as wallmart just has a kiosk you can plug a thumb drive I to also I have not been cropping any of my images. Thank you for your help
08-17-2022 08:41 PM
Thanks for that. Can you give me the pixel dimensions of a photo you are trying to print and its MP value please?
08-17-2022 08:50 PM
Sorry I don't know how to find that info and I don't currently have my laptop with me
08-17-2022 09:01 PM - edited 08-17-2022 09:06 PM
OK, no worries... Perhaps this might help. It's a guide to the size of image file you need to print various prints outputs. To get an idea of this look at the dimensions of your image in pixels. For printing (as a guide), given the likely print output resolution is 300PPI you translate that to your file size as follows:
For an 8" x 10" => 8x300 x 10 x300 or if you will print Length x width x resolution(squared). So, applying that in this example, the resolution for an 8x10 would be around 7.2MP. If, on the other hand, the printer resolution was set at 600 DPI, then the file size would be 8x600 x 10x600 = 48MP! So printer resolution has a huge impact on the file size you need.
Check out this article: https://www.photoworkout.com/print-resolution/ , it views the relationship from the other direction, so to speak - check it all out first.
08-17-2022 09:27 PM
Thank you for the information the link was very helpful. Can't wait to get in front of my computer and play around with some photos.
08-17-2022 09:30 PM
Good luck with that. Come back to here if you need to explore this further.
