EOS Rebel T7 Banding
chrysedward
This happens once I start taking pictures, does anyone know why?
10 REPLIES 10
Tiffany
Moderator
Moderator
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what model Canon equipment you are using. Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
Canon EOS Rebel T7
jrhoffman75
I'm guessing your problem is the alternating dark and light banding? Are you using an app or is that a camera photo of the camera LCD?
Greetings chrysedward,
I haven't done any live view shooting from my mobile device recently. Are you shooting in RAW? If so, this might have to do with the camera being set with a 3:2 portrait aspect and your mobile device being designed with a 16:10 wide aspect. Also check the "auto-rotation" settings on the phone. If its "locked" it may not allow the image to rotate and display as you expect.
Mobile devices use a taller and more narrow aspect these days. If someone else doesn't answer sooner, I'll try when I get home tonight and let you know what I see on my device.
chrysedward
Thanks for the replies guys, this is an issue that happens from the camera itself and from the application on my phone, pictures come and gray and dull, even when uploaded onto my laptop
This is a camera photo, after about 10 minutes of taking pictures they don’t come out with color nor vibrance, as well as the banding you mentioned
I Tried switching from RAW, same issue occurred within 10 minutes
Sounds like the camera should be sent in for check. Give Canon a call at (866) 261-9362.
I feel terrible. Here I was thinking he was referring to the aspect. Totally missed this. I thought this was a model sitting on a stool in front of a striped background. Thats what I get for reading from my phone. @chrysedward do you have another memory card you can test your camera with? Only full size cards should be used.
