EOS Rebel T6i Flash Will Not Activate
alexandeporter1
Canon t 6 i camera flash will not activate, but will fire with an external hot shoe flash. Help.
3 REPLIES 3
deebatman316
Can the built in flash be popped up manually in the creative zone ie (M, Av, TV & P) modes.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
ebiggs1
If it is not popping up you can help it. Set the camera so that it will try to pop the flash up and quickly use your finger nail in the crack between it and the camera to help it. It is common for dirt to get on the linkage which becomes inoperative. A drop of alcohol will clean it and a tiny, tiny drop or WD40 will lube it.
If it pops up but doesn't flash the bulb is probably blown out.
EOS 1DX and many lenses.
Anonymous
Not applicable
If it will not pop up, it may be caused by a stuck switch plunger on the side of the hot shoe. Its purpose is to detect if an external flash is in the hot shoe to keep the internal flash from popping up and hitting the external flash. If this is the case, you can clean the plunger to free it up.
