06-10-2022 02:11 PM
Hiya! recently I've attempted to connect my Rebel T6 camera to my computer using the Mini USB to USB cord. Unfortunately, my computer didn't recognize my camera, even after installing new firmware for the camera, installing updated versions of EOS Cam utility, and all of the drivers etc.
Still, my T6 camera doesn't connect, even after checking the batter charge, making sure I'm in movie mode, and making sure I turn the camera on, before plugging the usb cord to the back of my computer's motherboard.
I've made sure my camera was compatible with the EOS Utility, it on the forums, my camera was listed as a compatible camera.
06-10-2022 02:15 PM
I've also attempted to use different USB cords that fit my camera, and also attempted to use different USB ports on the back of my motherboard. Still no effect, and windows still doesn't recognize my camera.
06-10-2022 08:22 PM - edited 06-10-2022 08:37 PM
Do you ave access to a different computer? That might clarify where the problem is.
06-10-2022 02:55 PM
Does the T6 have WiFi? If so, is it switched off?
06-10-2022 03:03 PM
Yes, I have made sure the wifi function was switched off, but still no luck.
06-10-2022 04:10 PM - edited 06-10-2022 04:10 PM
If you wish to connect your camera to a computer, Canon are extremely specific about what cable spec to use. I have seen similar issues to yours, where people have tried different cables without success, and essentially you need to use exactly that cable type:
You can find the cable spec for your camera at this link: HERE
06-10-2022 04:16 PM
So, my camera looks like it doesn't support the cable listed on the site you listed. My camera has a Mini usb to usb connector to it.
06-10-2022 04:29 PM - edited 06-10-2022 04:31 PM
The cable listed on the site I gave you the link to shows:
EOS 1300D/Rebel T6 | IFC-400PCU | USB 2.0 Type A to Mini USB Type B cable |
Which is what you say your camera has the USB Type A goes to the computer, the Mini USB type B goes to your camera. There are lots of similar USB cables out there, but you need specifically this type by name: IFC-400PCU
06-10-2022 05:26 PM
I recently just received a new cable. It is the IFC-400PCU variant, but still no luck with the computer recognizing it.
06-10-2022 11:01 PM
When you say 'IFC-400PCU variant', was the cable specifically identified as that in the packaging or purchasing docs? Even if it looks that that, it may not have the exact wiring configuration required to make this work.
Is your desire to connect to your computer for streaming purposes or to download files?
