06-10-2022 02:11 PM
Hiya! recently I've attempted to connect my Rebel T6 camera to my computer using the Mini USB to USB cord. Unfortunately, my computer didn't recognize my camera, even after installing new firmware for the camera, installing updated versions of EOS Cam utility, and all of the drivers etc.
Still, my T6 camera doesn't connect, even after checking the batter charge, making sure I'm in movie mode, and making sure I turn the camera on, before plugging the usb cord to the back of my computer's motherboard.
I've made sure my camera was compatible with the EOS Utility, it on the forums, my camera was listed as a compatible camera.
06-11-2022 02:43 AM
Heya! Thank you for replying! I plan on using my camera for streaming on discord, video production etc.
06-11-2022 03:47 AM
And the cable question???
06-13-2022 08:18 PM
The article referred to does not give any "specific" cable requirement other than connectors. One end must be a USB-A connector to go to the computer. The other end is a USB mini-B, or a USB-C on the newer cameras. This is all obvious. The wrong connector just doesn't connect.
I use some old USB cables that came with Canon pocket digital cameras, as well as other no-name cables. These are not even USB-3 rated. All work fine on my EOS Rebel T1i, 50D, 60D, and 6D, Powershot G5, G11, SX200.
It doesn't require EOS Utility or any other software for the computer to recognize the camera. Windows takes care of that. If your camera is not being recognized, you could have a bad USB port on it. Have you connected any other cameras to the computer to see what happens?
12-16-2024 05:42 AM
Have you figured this issue out? I’m having the same exact problem.
12-16-2024 05:50 AM
Welcome.
So there is no confusion, please state your exact problem.
1. what camera model and computer operating system?
2. are you trying to use a software product or just connect to the computer to access camera card?
3. is the cable you are trying to use specified as a data cable or just a charging cable?
12-17-2024 06:07 PM
My camera is an t6 rebel
When I turn on my camera and connect it my Mac, the EOS software doesn’t recognize the device. I’ve tried reinstalling multiple times (latest update) and still nothing. I’m currently using the same usb cord that came with it. I have confirmed it still works on other devices.
12-17-2024 07:13 PM
"Charging-only" cables exist in USB-Micro B only. Not USB-Mini B, which is what the T6 uses.
12-17-2024 10:45 PM
What version macOS?
12-18-2024 03:22 PM
Big Sur 11.17.10
12-18-2024 03:44 PM
Can you see the camera if you run Apple Image Capture?
