EOS Rebel T6 Lens and Flash Suggestions
Candyn1251
I have the 75/300 lense and a df-400 power extra flash. I shoot racing photography. I wonder what other lenses or flashes would help create sharper photos? Thank you!
23 REPLIES 23
Tronhard
VIP
VIP
I can't comment on the flash, but the Canon 75-300 lenses are all very poor optically.  There are alternatives that are much better, but we need some more information to give you the most appropriate solutions.
1. Camera or cameras are you currently using?
2. What is your budget?
3. What is your preferred focal range?
4. When you say racing photography, what kind of racing? Horse, yacht, motor, indoor or outside?
cheers, TREVOR
Waddizzle
The EF 75-300mm lenses seem to be designed to teach you about photography more so than capturing stunning photos.  To be fair, though, you can capture pretty good still life images between 100mm and 200mm using a tripod using the center AF point to focus.
Using a flash is highly inadvisable for any type of sports photography.  What camera body are you shooting with?  What is the range of typical focal lengths that you use with the 75-300mm lens?
Help someone to help you.  Post a sample photo of your work so that people can get a better “picture” of what type of results you are getting.
I am using the rebel eos t6 and the range is 5 ft to 30 feet.  
Canon eos rebel t6.
minimal.
preferred focal range? 5 to 50 ft depending on car.
Does your 75-300 give you a big enough field of view at that distance? For example, the image you provided does not show the whole car.
If you look across the range of images you consider successful, what focal ranges are you shooting at?
Also, in part as a matter of curiosity, what is the reaction from drivers or the organizers to you using a flash so close to the racing?
cheers, TREVOR
The image provided was zoomed in to close. Ivan be 5 feet from the car or 50 feet from the car depending on where they ride on the track. I have had no complaints of the flash usage as they are used to it!
Most sporting events do not allow flash photography. Are you having problems with low light. You can look into the Canon EF 70-200mm F/2.8L IS III USM or the EF100-400mm f/4.5-5.6L IS II USM lenses. Since the lenses are stabilized this will help in low light. The 75-300mm is one of Canon's worst lenses but it can be a good starting point.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT, 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
"I have had no complaints of the flash usage as they are used to it!"  Fair enough.  Part of the reason I was asking was if you wanted to be able to be free of depending upon the flash, but I'll let that one lie.
Can you please advise what focal lengths you tend to shoot at, as opposed to the given 75-300 of the lens you are using.  There is a point to this. If you shoot only up to say, 200mm, then we can look at a different class of lens to find you the best solution.
cheers, TREVOR
Friends and Family
