EOS Rebel T6 Lens and Flash Suggestions
Candyn1251
I have the 75/300 lense and a df-400 power extra flash. I shoot racing photography. I wonder what other lenses or flashes would help create sharper photos? Thank you!
23 REPLIES 23
deebatman316
Hi, Trevor I cannot find a solution button for that post.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT, 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Again, Demetrius, that comment about clicking the resolution button is NOT aimed at you. 😶
My comments, unless specifically addressed to you, will always be to the OP, in this case, CANDYN1251.  Only the OP can mark an issue as resolved.    You need to see less this as a conversation between that others are having with you, and see it as us all working to resolve the issue for the OP.  That is why I state things you might think are obvious to you, but are likely not to them.
cheers, TREVOR
I guess you missed my post where I said pretty much exactly that.  However, it seems that the OP wants up to 300mm, so the 70-300 series will give them a little more at the wide angle end as well as far better optics and stabilization.
cheers, TREVOR
I agree about the flash.  Here that would not be allowed for health and safety reasons, but again I am not where the OP is...  Given in their post below that their budget is 'minimal', and they are using a T6, I don't think the L glass you suggested is going to be a financially viable solution.   They might be able to find a good used 70-200L MkI or MkII but the autofocus on the EF 70-300 IS USM MkII, which uses Nano-USM motors is blazing fast and it has better IS than the older L-series lenses.
cheers, TREVOR
