06-09-2013
02:18 PM
08:52 AM
I have a RebelT3i. On the viewfinder screen, in any shooting mode, in the lower right, just above the battery status indicator, I get a flashing indicator "Exp.SIM". I have looked through the Owner's Manual and can't find out what this means. Any clue?
Thanks!
02-23-2017 11:16 AM
@Angelaoh wrote:How can I get the Exp.Sims to go off so I can take the photo as is or go on to another photo without having to reset everything?
I suggest using the viewfinder, instead of using Live View and using the DSLR as if it were a cell phone camera. Besides, extended use of Live View not only wears down your battery, it will also cause your image sensor to overheat with extended use.
02-23-2017 12:22 PM - edited 02-23-2017 12:26 PM
Go back and read all of the earlier posts in this thread and in the other thread to which you posted this question. They may throw some light(!) on the issue.
06-29-2017 09:33 PM
11-19-2017 10:14 AM
Did you get this issue resolved? I have a similar problem
11-19-2017 11:18 AM - edited 11-19-2017 11:22 AM
@aileen wrote:Did you get this issue resolved? I have a similar problem
I strongly suggest that you start a new thread of your own. When taken at face value, your above comment is pretty vague.
[ EDIT ] BTW, the green check mark means a solution was found for the original issue, because only the original person who started the thread can create the green check mark. In other words, I suggest that you read the through the thread.
11-19-2017 12:35 PM
Thanks! Will do! New here to canonCommunity!
11-21-2017 12:58 AM
11-21-2017 07:04 AM
@Alyssa13 wrote:
Can somebody tell me what exp Sim means on my EOS rebel t6i and is there any way to fix it.Also why is my camera blinking a orange-red light or is the exp Sim causing that.
Exp Sim ("exposure simulation") means that the camera is trying to show you the picture in its true brightness, rather than brightening it to a standard viewing level. The flashing is probably a "blown highlight" warning.
The camera's instruction manual undoubtedly does a better job of describing these features than I could.
11-21-2017 10:44 AM
If you are talking about the orange light on the front of the camera it is either the red-eye reduction or telling you that the delayed shutter is delaying.
08-12-2022 05:09 PM
Very well said Bob. In other words if the light meter in the camera cannot read the brightness of the scene, the autofocus is "null and void". I had the same problem on my EOS M200 until I realized that the lens cap was still on! LOL A little too dark to get an exposure reading. ha,ha
