06-09-2013
02:18 PM
08:52 AM
I have a RebelT3i. On the viewfinder screen, in any shooting mode, in the lower right, just above the battery status indicator, I get a flashing indicator "Exp.SIM". I have looked through the Owner's Manual and can't find out what this means. Any clue?
Thanks!
07-11-2016 10:44 PM
07-12-2016 09:09 AM
OkayLook:
Start your own topic and answer some basic questions:
What camera?
What lens?
What exactly happens?
Are you farther than the closest focus distance for the lens?
Can you focus in live mode?
Can you manual focus
08-21-2016 08:06 PM
I am having the same issue with exp.SIM appearing on my screen. I have a EOS Rebel T5. I'm using 18-55mm IS Macro lens. I keep seeing on here about resetting the default settings. I went into my menu looking for this option. I could not find it and then I looked on the CD instruction manual. It was showing more options on the menu screen than I have. Please give me step by step ways to fix this.
08-21-2016 09:29 PM
@Caycee wrote:I am having the same issue with exp.SIM appearing on my screen. I have a EOS Rebel T5. I'm using 18-55mm IS Macro lens. I keep seeing on here about resetting the default settings. I went into my menu looking for this option. I could not find it and then I looked on the CD instruction manual. It was showing more options on the menu screen than I have. Please give me step by step ways to fix this.
I think you're overcomplicating this. As has already been pointed out in this thread, the "exp.SIM" display is a side effect of there not being enough light for the autofocus mechanism to operate successfully. The cure is to provide more light, either by brightening the scene or in the form of an autofucus assist beam from a Canon flash unit. Resetting the camera to factory settings is both unnecessary and unlikely to cure the problem.
And yes, recent Canon printed manuals tend to be abbreviated. But the one on the CD should tell you what you need to know.
09-14-2016 12:00 PM
02-14-2017 08:49 AM
I have the same issues.... doesn't seem to matter the light situation or distance of object, happens with both lenses. Frustrating as I've got a new grandson and you only have so long to capture that precious look....
02-14-2017 10:29 AM
Then don't use live view. *everything* is faster when you use the viewfinder.
02-23-2017 11:01 AM
This camera is probably much more camera than I will ever learn to use. I am so untech. inclined but it was a gift. How do I get the flashing white Exp.Sims to stop flashing? I am indoors and it came on when I was outdoors. I cannot get it to turn off.
02-23-2017 11:04 AM
How can I get the Exp.Sims to go off so I can take the photo as is or go on to another photo without having to reset everything?
02-23-2017 11:06 AM
Just ignore it, it does not affect the picture at all.
