04-29-2023
03:53 PM
03:54 PM
I currently have a canon Rebel t3 with a new SD 256gb. When I went to put the chip in to my MacBook using an adapter ( to look at my photos) it’s unable to read the chip & now I can’t access my photos. Also when I put the chip back into the camera it says “card can’t be accessed”
what should I do ?
04-29-2023 10:55 PM - edited 04-30-2023 08:36 AM
You mentioned an adapter. Was this card full size or micro? Micro SD cards are not recommended. It sounds like the card has become corrupt or unreadable. If the card cannot be read in the camera or on the computer, recovery is likely the only option.
04-30-2023 06:53 AM
Could this "adapter" really be a USB SD Card reader.
04-30-2023 08:30 AM
It’s a USBC adapter that plugs into my Mac book air. What’s the best memory card for a canon Rebel t3?
04-30-2023 08:30 AM
04-30-2023 08:36 AM - edited 04-30-2023 08:49 AM
Look into a full size SD Card class 10 SD Card. DO NOT use Micro SD cards in an adapter. These are known to cause problems with cameras. Use multiple smaller 32GB SD Cards. Do Not use 1 large SD Card. If the card were to fail all of your pictures would be gone. Using multiple SD Cards will lessen the chance of this happening. Is your current SD Card size or a micro SD Card in an adapter. I noticed that you "chip".
04-30-2023 08:36 AM
@Demetrius,
It certainly could be. We don't have much to go on.
04-30-2023 08:46 AM - edited 04-30-2023 08:47 AM
The OP confirmed that this "adapter" is a USB Type C SD Card Reader. But I will also check if there using a Full Sized SD Card.
04-30-2023 08:48 AM
Would a 64 GB SD card from Walmart be okay?
04-30-2023 08:56 AM
I would try a 32 GB SD Card first. Older cameras are picky about 64GB or larger SD cards. I would go to Best Buy or another reputable retailer to buy memory cards. B&H Photo & Adorama are examples of reputable places. Amazon & eBay are NOT reputable places to buy SD Cards. There have been horror stories in the forum. That they got counterfeit memory cards.
