04-29-2023 11:30 PM - edited 04-29-2023 11:37 PM
Canon Rebel T7 Repair ?
04-29-2023 11:49 PM - edited 04-30-2023 12:00 AM
Sorry to hear. 😞 Water damage. Repair is probably not worth it. Do you have many lenses? If so, which?
Some options:
Canon T7 Refurb - $299. Same 1 yr Canon warranty as new.
Good: Shop Canon Refurbished EOS Rebel T7 EF-S 18–55mm f/3.5–5.6 IS II Lens
But I would turn this into an upgrade opportunity.
Better: T8i - Shop Canon Refurbished EOS Rebel T8i EF-S 18-55mm f/4-5.6 IS STM Kit
Best: Consider a new mirrorless body. Your other Canon lenses could probably be adapted to it as well.
EOS R10 RF-S18-45mm F4.5-6.3 IS STM Lens Kit (canon.com)
Depending on budget, we might have other suggestions. In any case, trying to fix a water damaged T7 will likely exceed the cost of a refurb.
~CarePaks Are Worth It
05-01-2023 08:37 AM
I agree with Rick that repair of this body after water damage just isn't practical given the low replacement cost because any proper repair will greatly exceed the cost of replacement. Cameras are both electronic and mechanical devices and any significant water entry has degraded the shutter/mirror mechanism in addition to any damage done to the electronics.
Very pure fresh water is the least damaging but people rarely drop their possessions into distilled water while even a heavy rain results in the oil/salt buildup from your skin working its way into camera bodies that aren't well sealed against weather and only Canon's most expensive series have that sort of weather sealing.
We live in a world where most consumer products are designed for replacement rather than repair even when the fault is relatively minor. Water into an unsealed consumer camera is not relatively minor.
Replacing a camera body that was functioning prior to moisture isn't a happy event but congratulate yourself on actually using your camera instead of leaving it sitting on a shelf as many people do. I use four 1DX II and III bodies and of the three, I purchased one of the two 1DX II bodies used. It was at a very good price and the prior owner apparently liked to see it sitting on a shelf because it was in pristine condition with a shutter count under 1,000 exposures (in a body rated for 400,000 before recommended replacement). Camera are meant to capture things to look at, not to be looked at sitting on a shelf.
Rodger
