06-14-2023
09:13 PM
09:23 AM
I am having this same issue, however, running Ventura on an M2. (T2i - yes, I should upgrade but it's out of the question financially).
When I connect my camera and power it up, the menu screen shows a "busy" banner for about 10-15 sec then goes blank. At that point if I tap the menu button, the menu opens but is frozen and I'm unable to navigate.
On my computer, it's not recognized in any way.
All I'm looking to do is be able to transfer my images off without having to pop my memory card out all the time. Would love to be able to use it for remote operation as well but at this point, seems like a long stretch.
Is Canon supporting this product still? Based on how old this thread is and the lack of input from anyone, I'm assuming I'm beating a dead horse. But...with that said, if anyone has a fix and/or workaround, I'd love to hear from you!
06-15-2023 01:29 PM
To prevent forgetting SD Cards. I would suggest carrying additional SD Cards in your camera bag. Then set your camera to prevent it from taking pictures. Without an SD Card inserted in the camera. 32GB should be plenty for an older Rebel series camera.
06-15-2023 02:19 PM
@zagged,
Sounds like you have a plan and path forward. Keep us posted. 🙂
06-16-2023 10:11 AM
"... was that constantly popping this in/out was actually not great for the camera or the card. Figured by doing this pretty much every time I use my camera, I'd be wearing internal connections out or something like that."
This would be very near the bottom on the "Great List of Things" to worry about. It is also a good idea to remove the lens from time to time as it tends to keep the contacts working. This stuff is designed to be used. It is not designed to be left static.
