EOS Rebel T2i Images not saving on SD card
fishers1976
I’m having an issue with my camera not saving the photos to the SD card. It’s a brand new SD card which I’ve formatted to the camera. I’ve verified that all the settings are correct. The SD card is inserted correctly and the battery is charged. When I take a photo, it seems normal. The display looks like the photo was taken. However, when I go to view the photos, I get the message “No Image”. Nothing was saved to the SD card. Does anyone know what would cause this?
12 REPLIES 12
Thank you for the suggestions. I will try those!
fishers1976,
Is it possible that you are accidentally formatting your card?
I know you said that you can't go to the low level formatting box, but that is sort of the default. If you hit OK, then the card formats. The reason I ask is that I just formatted my card, and I got the same message you did.  "No Image".
Steve Thomas
Hmmm…strange.
I have an appointment with the Geek Squad at Best Buy tomorrow. I’m hoping they can figure out what’s causing that.
