08-01-2023
03:02 PM
03:05 PM
Any ideas on why my camera turns on and works normally for a few minutes and then the screen turns into a bunch of lines and then it wont turn back on for a while??? I rarely use the camera ever.
canon eos rp
08-01-2023 03:06 PM
Are you using a Canon-branded battery? What lens do you have attached? Try removing any attached lenses, any other accessories, remove the memory card as well. Remove the battery, let it sit for a bit, then re-install the battery and power on and observe.
If you continue to have issues, you should call up Canon and look at scheduling a repair.
08-02-2023 10:35 AM
Yes i am using a canon battery, my lens is the rf24-105mm F4-7.1 IS STM. I’ve removed everything and still has the issue
08-02-2023 11:56 AM
You could try resetting the camera as well, but I doubt that will fix this issue.
Time to call up Canon and schedule a repair.
