12-12-2022
12:17 PM
09:25 AM
I have one Canon Eos RP, and I have noticed that sometimes when i will take a pic, even if the camera is straight on the vertical, when you look at the LCD the photo is crooked a little, i don't know what is but probably is some bug on the camera, anyone knows something about it? How to solve the problem?
12-14-2022 07:37 PM
Greetings gabrielaminuzzo,
Using the electronic level will allow for users to get close on leveling their camera when taking photos but it may be off by a few degrees in either direction. In case the level is completely off then you may clear the camera settings to restore them back to factory default to see if it helps resolve the issue. I will provide you with a link to the user guide, and the steps to clear the settings are on page 410.
https://gdlp01.c-wss.com/gds/3/0300033693/06/eosrp-ug5-en.pdf
In case the issue persists then you may send the EOS RP camera to our facility for service.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
