EOS R8 - poor buffer/write performance / firmware downgrade
anzee
Hello!
I have a Canon Eos R8 since june 2023. I am using it as a hybrid camera for photos and videos.
Since the very beginning I am also using Tascam XLR audio adapter for the hot shoe. Filming mostly in 4k 50p light setting.
In december 2024 I found out, that I suddenly get audio problems (out of sync, scratches in audio,.. audible while montoring earphones and also in written file) when filming in 4k50p "light", although I used this setting for at least a year before without any problems. If i continued to film, the camera buffered out (with icon) and stopped filming. It helped to change the setting to 4K25p "light", but from time to time this also results in poor audio and buffer being filled. In HD the problem is not visible.
First thing to change was the SD card. Usually I was using V30 sandisk 64GB card, changed to 128GB V60 card. No difference. Tried also some other cards, with no luck (haven't tried V90, but it worked with v30 card before..). Tried different batteries with different charge states - no luck. Tried different lenses (rf70-200 f2.8, rf50 1.2, rf24-105, rf15-35), no luck. The problem persists if recording sound from Tascam, Rode NTG2 via jack or using internal microphones.
The last idea was the firmware. I think i upgraded to 1.4.0 firmware from 1.3.0 sometime in november. But cannot downgrade back to 1.3.0. to check that.
Has anyone else experienced this performance issue after upgrading to 1.4.0 firmware? Or is there a way to downgrade the firmware to an older version, to check.
Side question - anyone else also thinks that the HD quality of footage from R8 is really poor, so is the slow motion, but the 4k is just perfect...
regards, Anze
17 REPLIES 17
anzee
Ok here we go...
Recording low datarate scene with my R8 using only internal microphones and some youtube interview played through mobile phone pointed towards the mic. Other camera is R5 mk1 recording the screen of R8. Full screen video and audio is captured with R8, picture in picture is a view of R8 lcd screen. It is interesting, that the footage is stopped at approx 30s, while the camera shows that is recording for quite some time until the buffer icon is shown. Shortly the buffer is full and R8 stops. You can hear the distorted audio coming from the R8 file...
Like I said, no. Same setup as the whole time before, for more than 1,5 years. The only difference I can think about is the firmware update that I made, or some unknown and invisible mechanical problem that could be the cause..
anzee
So, no ideas how to downgrade the firmware? Would the service centre be able to do this?
stevet1
anzee,
Just as a test, have you tried taking it out of 4K and just filming in HD for a bit?
Steve Thomas
anzee
Yes Steve I did. In HD it records flawlessly for at least 15mins, that's how long I tested recently.
Only because you seem to be the only user reporting this type of issue, I doubt that the firmware update has anything to do with it.
Is your camera giving you over temperature warnings?  If not, it should during long periods of 4K high speed recording.
You make a point with noone complaining, true.
The camera did give me over temp warnings, usually when filming in direct sun or also just turned on on the sun the bar was visible and slowly rising.
In these last months we have colder temps and not that much sun, so I didn't see the warning for some time. And I cannot film in 4K that long that it would give me the warning, as it buffers out before. Will try to put the camera in warmer environment and see if the temp warning shows
anzee
Sent the camera to the Canon service. At the end, it was a motherboard failure (apparently due to water ingress). Now it is working great again. Thanks to all that helped!
