EOS R7 won't allow firmware update
Clivefw
I'm trying to update my R7 firmware from 1.3.1 to 1.5.0. I've downloaded the file and copied it to a formatted card but when I try to load it onto the camera I get a message saying:
Update Firmware?
1.3.1 > 1.5.0
EOSR7150.FIR
Cancel      OK   (boxes)
The trouble is the OK box is greyed out so I can't load it. Any ideas?
7 REPLIES 7
kvbarkley
Did you unzip it?
mac or PC?
Clivefw
Yes I think so, I've got the .FIR file. PC.
Tronhard
VIP
VIP
Did you try selecting the greyed out OK option?
cheers, TREVOR
p4pictures
You have to use the main dial next to the shutter button to move the selection to the ok button then press the SET button as the touchscreen is not active at that stage of the firmware update.
Brian
err - that button is not next to the shutter button but is at the back of the camera to the right of the screen door - but yes click right then set.
lorenbc
Yeah, it took me a while to figure it out, too.
You need to use the right arrow on the 4 way selector on the lower right side back of the camera (I forget what it's called) to move right and select the OK button.
Good luck!
Loren
He is talking about the main dial:
#4 in this image.
Either control will work.
