EOS R7 will not turn on
Photofanatic
I bought the camera new and have had it for 3 days. I updated the firmware to 1.6 and used it for a few sessions. I was taking some pictures of some birds and pressed the photo review button to see the images on the touch screen when it lost power and will not turn back on. I have tried charging and replacing the battery, replaced the memory card, changing/checking lens connections. I left the camera in the power on position over night without a battery, memory card or lens attached hoping it would power back on this morning and no luck.
Has anyone else had this problem and found a reasonable solution? I’m worried that I will have to try to send the camera to Canon which will be a massive inconvenience.
Thank you
#canonR7
Day 3 of camera ownership... Go ahead and contact Canon but if the camera is not 100% I'd contact the retailer and exchange it.
7 REPLIES 7
March411
You best bet is to reach out to Canon support for assistance.
800-385-2155 or 800-652-2666
Marc
Windy City
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Hi, Photofanatic!  To clarify, 1-800-652-2666 (which spells 1-800-OK-CANON) reaches our tech support team while 1-800-385-2155 reaches our sales team.
I did and they were very helpful thank you
Thank you
I contacted Canon and they were as helpful as could be and ultimately returned the camera to the vendor. I was hoping for a DIY solution or a repair from Canon because now I will be purchasing another R7 hoping not to encounter the same problem. Thanks for your advice
I'm sure the replacement will be perfect.  😃
