EOS R7 color anomaly in astro photography
mdphotography
Rising Star
Rising Star
my first attempts at astro photography and I noticed a pink spot and streak on almost all my shots, regardless of exposure time (2 - 30 sec), iso (100 - 32000) and aperture (f2.8 - f20).  I was able to remove it in post production but was hoping somebody had a technical solution.  You can see it just below center to the right in the example below and it appears in every shot but the "blue hour" ones, regardless of where I pointed the camera.  I was in a pretty dark camp site, but it's possible there was some stray light from one of the other campers.
body: EOS R7
lens: Sigma 18-50mm F2.8 DC DN | C
iso5000 - f/14 - 18mm - 30 sec
I do a lot of astrophotography.  I have since the film days in the 80's.  I've never seen anything like this from settings being off, or even close to this from the settings... especially with it being a perfectly straight horizontal line.  This is very often a sensor issue.
Gary
Lake Michigan Area MI
Digital Cameras: Canon EOS R6 Mk ll, EOS R8, EOS RP, ...and a few other brands
Film Cameras: Mostly Pentax, Kodak, and Zenit... and still heavily used
9 REPLIES 9
kvbarkley
Does it happen when you take a "dark frame" - just do an equivalent exposure with the lens cap on.
yep - saw it....I think this means I may have a bad lens   😕
at least it's new and still under factory warranty!
That is more likely to be caused by the image sensor, than the lens.
Gary
Yeah, often this is when the camera does not compensate properly for the rows of focusing sensors.
mdphotography
Rising Star
Rising Star
is that a physical issue with the camera body or do just need to finesse the settings a little more?  this was my first attempt at astrophotography so I expect a bit of a learning curve
Contact Canon and discuss it with them.
Gary
mdphotography
Rising Star
Rising Star
thanks for the advice!
When you take a proper dark frame with the lens cap on no light comes through the lens.
