12-08-2024 12:55 AM - last edited on 12-08-2024 08:14 AM by James_C
When I select TV the camera shows AV. Bulb mode is replaced by manual.
This is about the 4th time this had happened. But this time I can't clear it.
12-08-2024 10:00 AM
The rotary encoder switch under the mode dial is causing this problem If in the U.S. contact 1800 OK Canon for service. Get a quote first before making the repair.
12-08-2024 10:54 AM
Thank you for your prompt reply. I am in the UK. I Will contact canon here.
