09-02-2022
05:49 PM
09:09 AM
I am new to my Canon R6 and discouraged with information on lenses. I just received the TTArtisan 50mm f/2 Lens and although I can see through the lens, my shutter button will not work. I've removed/replaced it. I've tried using my ring adapter - though not supposed to be needed - and found it listed on lenses to fit the R6 body. I wish there was a live chat with Canon for help. If anyone here knows if this is a user error or if this lens is not meant for an R6 body, please help.
Thank you!
09-02-2022 06:38 PM - edited 09-02-2022 06:42 PM
The lens a manual lens with no electrical connection. Look in the menu section for the setting to actuate shutter without lens (page 796).
09-02-2022 09:05 PM
Hi AlanaD,
Fully manual lenses do not communicate with the camera. Due to that the camera doesn't detect a lens is attached and will refuse to take a photo. If you enable the setting in jrhoffman75's response you will be able to take photos when that lens is attached.
To enable that put the camera into either P, Tv, Av, or M photo mode and press the Menu button. Go to the fourth page under the Custom Functions tab (the orange camera icon second from the right), and set Release Shutter w/o Lens to On. Once you do that you will be able to take photos with a fully manual lens attached.
09-02-2022 09:03 PM
So grateful for your response. I'll do that now. Thank you!
09-02-2022 09:05 PM
Hi AlanaD,
09-02-2022 09:16 PM
Hazel!! SO SO grateful for these steps. Blessings!!!
09-04-2022 12:17 PM
My question is, out of curiosity, why buy the TTArtisan 50mm f/2 Lens? Very much inferior to the RF 50mm f/1.8 STM Lens. It can't be simply price or size since the RF 50mm f/1.8 STM Lens is not a whole lot more costly new and nearly the same price used. Plus the RF 50mm f/1.8 STM Lens is designed to use all auto functions on your camera. And, it can be used manually.
09-04-2022 12:24 PM
@ebiggs1 wrote:My question is, out of curiosity, why buy the TTArtisan 50mm f/2 Lens? Very much inferior to the RF 50mm f/1.8 STM Lens. It can't be simply price or size since the RF 50mm f/1.8 STM Lens is not a whole lot more costly new and nearly the same price used. Plus the RF 50mm f/1.8 STM Lens is designed to use all auto functions on your camera. And, it can be used manually.
One has a list of $69 USD. The other has a list price of $199 USD.
