02-20-2026
04:28 AM
09:15 AM
02-20-2026 08:11 AM
To guarantee that Canon engineers see this, go to the Canon USA homepage and look for the little [+]feedback button. Click that and send your feedback. You will need to register with Canon first, though.
02-20-2026 10:58 AM
I don't have the camera, but I see that you can switch the review off, and also select Hold, which I don't think would help.
Have you tried moving the slider with the joystick, or with the touchscreen? It seems that an overlay like this should be moveable or even resize-able.
02-20-2026 11:44 AM
This is kind of interesting. I've never used the rating system on my camera, in DPP or DxO. If may differ slightly since my body is older. I'll try to see if the slider can be moved on my camera.
In any event use my college's @kvbarkley suggestion to leave +[F]eedback.
02-20-2026 12:59 PM
Unfortunately the slider is semi - dumb - only shows position relative to all rated images
( joystick will not work ) Rated images can be browsed only by dial close to shutter
( and this needs to be setup - You can also setup to jump every x amount of images and more )
02-20-2026 01:01 PM
Rating in camera is transfered to Lightroom / Brideg / Photoshop
very important if you shoot people and want to hear their opinion / what they like
02-20-2026 04:57 PM
I recommend checking the Playback Info settings. This screenshot is from the R6ii manual.
02-21-2026 12:05 AM - edited 02-21-2026 12:05 AM
Thanks - of course I've been there - unfortunately there is no checkmark for removing the huge slider blob while
browsing rated images - note that this slider is not showing on every image while browsing images one and one
Toggling info doesn't improve the situation much ...
previous sample was with. info cleared.
