01-16-2024
02:06 PM
02:07 PM
My camera will not update the firmware 1.30. It just restates the camera without updating
01-16-2024 11:08 PM
As does registering it, as I have done
01-17-2024 06:58 AM
@lazya wrote:As does registering it, as I have done
How many SD cards are inside the camera when you do an update? I t recommend having only one card in the camera. I also use a dedicated card for firmware updates. I format it in the camera and then copy a the firmware to it.
An update can also be performed using the USB cable. But since you are having issues with a memory card update, then I would strongly discourage trying that.
01-17-2024 11:04 AM
Given the challenges, a call to Canon support might be warranted. They would be happy to assist you.
01-17-2024 12:18 PM
It finally updated! Thanks all! I removed the battery grip, put the FIR. on both extreme Pro cards. And now this time it is updating for some reason; I had already tried this before.Anyway, Happy that it finally worked.
01-17-2024 01:06 PM
Ah, I wonder if it was the battery grip being attached? Do you recall if the other cameras you had updated successfully had accessories attached?
01-17-2024 01:16 PM
Just my 5Dlll had a battery grip. It updated without problem.
01-17-2024 05:21 PM - edited 01-17-2024 05:22 PM
@lazya wrote:Just my 5Dlll had a battery grip. It updated without problem.
The battery grip being the potential problem sounds familiar. I’m almost certain another forum member had a similar issue and solution.
Are your battery grips for both cameras made by Canon? I use the Canon grip on my R6 mark II and have had no issues updating camera firmware.
08-09-2024 09:19 AM - edited 08-09-2024 09:20 AM
Generic Battery Grip was my issue! Removed and Firmware update done no problem.
09-06-2024 05:29 PM
Yep!! I was just having the same issues and removing the battery grip did it. THX!!
10-22-2025 06:12 PM
i just did the same! it works
