01-16-2024
02:06 PM
02:07 PM
My camera will not update the firmware 1.30. It just restates the camera without updating
01-17-2024 12:18 PM
It finally updated! Thanks all! I removed the battery grip, put the FIR. on both extreme Pro cards. And now this time it is updating for some reason; I had already tried this before.Anyway, Happy that it finally worked.
01-16-2024 02:25 PM
How are you updating the firmware? With an SD card? Or via software on a computer?
01-16-2024 02:28 PM
SD card
01-16-2024 02:39 PM
Is the file on your SD card using an .FIR extension?
01-16-2024 02:50 PM
I've updated my other cameras without incident, this new R6ii will not update.
01-16-2024 02:53 PM
What mode do you have the camera in? And when does the camera restart? At the point of powering it on, or are you able to navigate to the Firmware update menu, and select OK?
01-16-2024 03:10 PM
P mode. It will go to the screen asking me if I want to update the camera to 1.3.0. It then hesitates and then will restart.
01-16-2024 03:16 PM
I've tried 3 different cards. I think I will wait a week when I have more time to troubleshoot this.
Thank you for your time Ricky
01-16-2024 03:24 PM
This is from the Canon site, I updated mine yesterday.
Copy the firmware to the card
1. Initialize/format the card with the camera. As this will erase the contents of your memory card, backing up your images/videos to your computer before performing this step is recommended.
*Please see the cameras's instruction manual for information on how to inialize/format the card
2. Insert the card into the card reader and copy the downloaded firmware file to card's root directory
*The firmware file is contained within the Firmware download from our support website and has a *.fir file extension
Update the firmware
1. Remove the card from the card reader and insert into the camera
2. Turn the camera's power on and set the shooting mode to <P> mode
3. Press the <Menu> button to display the menu
4. Select <Firmware Ver.X.X.X> from the <Setup> tab on the menu and press the <SET> button
Hope it helps
01-16-2024 03:27 PM
Yep, did all that, still no go, but thank you for your reply.
