EOS R6 Mark II - only records multiple exposures as jpg?
Ms2thdr
What is the rationale for Canon changing this?  I would think they would encourage creativity rather than restrict it.  I am glad that my R6mii allows me to finally use my RF24-240 to take multiple exposures, but the fact that I now only have a .jpg to process afterwards almost makes it useless.  Is there any hope that Canon will change this or a way to let Canon know that it was a poor move to change it?  #R6mii #multipleexposure
18 REPLIES 18
While you cannot merge existing image files into a single multiple exposure, you can select an existing image file to be merged with a photo that you are about to capture.
You have reminded me about posts that  asked about why multiple exposure RAW files didn’t contain EXIF data.
Yes, that is true for many things, especially HDR, but it wasn't true for multiple exposures.  Up until the R6ii multiple exposures were recorded as .tif files.  I have hundreds of them to attest to that.  It's just that this is a big change and I don't understand the rationale behind it.
Thank you, I've done that.
So if this is the case, then why was it never like this before?  And a multiple exposure is definitely not like a print.  If you've never done a multiple exposure in camera you would think that, but for those of us who have we know that they need contrast, color and other changes to make them look right.  Just like a regular image that is shot in RAW.  I'm not asking that it is saved in RAW, that would be silly, I'm just saying that it is a change and for the worse not the better.
I think, even with the 6D it depended on whether or not you saved your raw files.
And that's yet another thing.  Before this change you could select RAW files as a base image for the Multiple exposure, now you can only choose .jpg.  Which is absolutely crazy for those of us who don't ever create images in .jpg in camera.  (Unless we are being forced to).
I notice, the CR2 from my 6D still has the Bayer pattern, but the white balance is baked-in.
I have already explained why.  The end result is a digital print.  Just because I have no interest in capturing does not mean I do not understand how multiple exposures work. I also noted that it was not clear what type of multiple exposure you were creating.IMG_0098.jpeg
The end result of multiple exposure is an image with undefined EXIF data.  You can create a multiple exposure image from an existing file and one you are about to capture.  The two files could have different times/dates, lens, exposure, WB, AEC,  etc.  Tell me,, what data should go in the EXIF?
The screenshot is about using an existing file on the memory card.  You could take a RAW photo today.  Turn off the camera.  Go capture another RAW photo the next day in a different location using a different lens, exposure, etc.
If the WB is baked in, then the file is no longer a RAW file.
