09-30-2024
01:35 PM
02:40 PM
James_C
Last night I had updated the firmware to 1.5.0 via the SD card method, waited for the process to finish, then closed out of the menus. When I pressed the shutter button, the EVF blacked out and the back screen turned black but stayed lit. I switched the camera off and nothing changed, the screen was still blank but illuminated. It was not until the battery was removed that the back screen stopped being illuminated and the camera truly turned off. Currently, the camera will not turn on unless the battery is inserted while the camera is switched on, and all that happens is the back screen illuminates. Have to remove battery all over again to turn it off. Has anyone else encountered this?
Tried both with/without SD cards and with various Canon and 3rd party EF lenses with the Canon adapter. Camera was purchased refurbished through Canon 2 weeks ago.
09-30-2024 03:21 PM - edited 09-30-2024 03:22 PM
I have a similar problem with my Volkswagen. If I try to take the key out before putting it in park, then put it in park and take the key out, I can't put the key back in until I turn the wheel 1.5 rotations to the left and push the key in while holding the wheel over. Only after performing this ritual will the car turn back on. Pretty weird. Interesting to see that Canon has adopted the Volkswagen design philosophy.
10-02-2024 06:11 PM
Greetings dkcr2,
I am sorry to hear that you are experiencing issues with your EOS R6 Mark II camera after updating the firmware. Per the description that you have provided, I would recommend on sending the unit to our facility.
Items purchased directly from Canon USA or from an Authorized Canon Dealer do include a one-year warranty if the item was purchased less than a year ago. You may view a list of Authorized Canon Dealers by clicking on the following link. I would recommend including a copy of your Proof of Purchase when sending in your item for the facility to review for any in-warranty service or repair.
https://www.usa.canon.com/internet/portal/us/home/contactus/where-to-buy/authorized-dealers
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
