08-22-2024
10:01 AM
10:55 AM
Howdy, I am new to the Canon ecosystem. I am sure this is an easy setting but would like some input. Would like to lock the F stop and speed and let the ISO vary. Any suggestions? Thanks and sorry if its an easy question.
08-22-2024 10:38 AM
It is not an easy setting.
However, Ken Rockwell says that the R7 will do it in Fv mode:
08-22-2024 10:16 AM
Hey there!
Welcome to the Canon Community! So that you get the most accurate info, it's helpful to know which Canon camera you're working with.
08-22-2024 10:38 AM
08-22-2024 10:51 AM
Sorry about that EOS R6 MII
08-22-2024 10:53 AM
Very cool. Thanks for the help. I will give it a shot (literally) (BTW, EOS R6 MII)
08-22-2024 10:55 AM
Thank heaven for Ken Rockwell! 😊
08-22-2024 11:08 AM
He says the R6II will do it, too. You might want to check out his usage guide:
https://kenrockwell.com/canon/eos-r/r6-ii.htm
08-22-2024 02:34 PM
You can use manual exposure mode, M on the mode dial, and then select the aperture and shutter speed you want, but leave ISO set to AUTO ISO.
If you really want to lock the shutter speed and aperture values, then use the multifunction lock and configure it to lock the main and quick control 1 dials. This will then stop you changing the shutter speed and aperture while the lock is active. Lock iOS the middle position on the power switch.
08-22-2024 03:30 PM
Thanks. Another great solution. Really appreciate it.
