EOS R6 Mark II Locking F stop and Speed and letting ISO vary
Chuckwalla
Howdy, I am new to the Canon ecosystem.  I am sure this is an easy setting but would like some input.  Would like to lock the F stop and speed and let the ISO vary.  Any suggestions?  Thanks and sorry if its an easy question.
kvbarkley
VIP
VIP
It is not an easy setting.
However, Ken Rockwell says that the R7 will do it in Fv mode:
8 REPLIES 8
Stephen
Moderator
Moderator
Hey there!
Welcome to the Canon Community! So that you get the most accurate info, it's helpful to know which Canon camera you're working with.
Sorry about that EOS R6 MII
kvbarkley
VIP
VIP
Very cool.  Thanks for the help.  I will give it a shot (literally)  (BTW, EOS R6 MII)
He says the R6II will do it, too. You might want to check out his usage guide:
https://kenrockwell.com/canon/eos-r/r6-ii.htm
Thank heaven for Ken Rockwell! 😊
p4pictures
You can use manual exposure mode, M on the mode dial, and then select the aperture and shutter speed you want, but leave ISO set to AUTO ISO.
If you really want to lock the shutter speed and aperture values, then use the multifunction lock and configure it to lock the main and quick control 1 dials. This will then stop you changing the shutter speed and aperture while the lock is active. Lock iOS the middle position on the power switch.
Brian
Thanks.  Another great solution.  Really appreciate it.
