12-10-2024
03:31 PM
05:39 PM
Tiffany
Why are the option for cropping aspect all greyed out in the menu? I want to switch my ##Canon r6II from 1.6 to full..What am I missing?
12-10-2024 04:04 PM
What lens are you using? If RF-S or EF-S, it will force a full frame R to only use 1.6 crop. There may be other settings that force this, but that is the first thing that popped in my head 🙂
Newton
12-10-2024 05:33 PM
Right now I have the Canon 17-55 2.8 lens on body.
12-10-2024 06:22 PM
You’re using a lens made for APS-C on a Full Frame camera. The camera will apply a 1.6x crop automatically to avoid vignetting. But this reduces megapixels. The camera has 24 megapixels in Full Frame mode but in 1.6x crop it’s only 9.4 megapixels. I would recommend looking into the RF 24-70mm F/2.8L IS USM or RF 24-105mm F/2.8L IS USM Z lenses as a replacement. To get the most out of the Full Frame sensor in the EOS R6 Mark II.
12-10-2024 06:25 PM
Thank you! I’m working on replacing my bodies, then lenses. It’s just too expensive for me to update all at once.
I appreciate your reply
12-10-2024 06:26 PM
If you check your manual you will see that it is noted on page 172, it goes into crop automatically and there is no option to change it while the lens is mounted.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
12-10-2024 06:35 PM
Yes there isn’t a way to use the Full sensor when an APS-C lens attached. The camera is locked into APS-C mode. It cannot be changed.
12-10-2024 06:49 PM
I have a EF 36mm macro that I use on my R6 MkII all the time and while you end up at 9.4 MP you still get some decent images. The first time I put it on I was trying to switch to FF knowing I would get some vignetting that I thought I would clean up in post.... I was denied!
And yes I was closer to them then I wanted to be....
Personal Gallery
