EOS R6 Brackets on screen
marylou1660
Hello
I have an image on my screen that I cannot get rid of and don't know what it is. I just got the camera and was playing with itcamera trouble.jpg
stevet1
marylou1660,
I don't own an R6, so I'm not sure how to get rid of it, but I'm pretty sure that's an electronic level. It's designed to help you keep your photos level and straight.
I have a T8i, and if I hit the Info button a couple of times, it will go away.
Your camera may require different steps. See what your manual says.
Steve Thomas
4 REPLIES 4
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, we will need to know what Canon camera gear you're using.  Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you
marylou1660
My camera is EOS R6
stevet1
marylou1660,
Steve Thomas
FloridaDrafter
@marylou1660 wrote:
Hello
Steve is correct. The INFO button on the R6, when repeatedly pressed, will toggle your LCD through several different info screens, one of which being the level option. Just keep pressing it until you get the LCD display you want.
Newton
Avatar
