EOS R50 vs EOS R10 - Choice of camera for bird photography
parthas
If I have to choose between canon EOS R 50 and Canon EOS R10 for bird photography, which camera should I choose and why so?
3 REPLIES 3
rs-eos
It's going to be more about the lens for this particular genre of photography.  However, one large difference between the two is that the EOS R50 doesn't have a fully mechanical shutter.  Electronic shutter-wise, you can capture up to 15 frames per second.  Whereas on the EOS R10, it does have a fully mechanical shutter that can capture up to 15 frames per second.  Or up to 23 frames per second with its electronic shutter.
Ricky
For wildlife photography, I prefer the R10 over the R50
Canon R10 vs Canon R50 Detailed Comparison (cameradecision.com)
The cameras are very similar as far as image quality, ISO performance etc.  The R10 is a little larger which will help with balance and larger lenses.  It has a joystick which I prefer.  Also better battery performance.
The R7 is a step up from the R10 and if you have the budget, would be another great option.
If budget is a main consideration, consider Canon Refurb.  No refurb deals on the R50 currently.
Shop Canon Refurbished EOS R7 Body | Canon U.S.A., Inc.
Shop Canon Refurbished EOS R10 Body | Canon U.S.A., Inc.
ebiggs1
R10 all the way.
EOS 1DX and many lenses.
Friends and Family
