05-28-2025
06:53 AM
08:40 AM
James_C
Help guys, my canon r50 goes black after I shoot a few times in high iso then it wont turn on or off, I have to remove battery to operate again. then I shoot at low iso and it still happens.
So I changed to jpeg and I can shoot a few more times before it blacks out again and wont turn on or off unless I remove and put abck the battery again.
06-02-2025 05:25 PM
Greetings alex23,
I'm sorry to hear that your EOS R50 camera is having this blackout issue when using the camera. Let's check to see if the issue may be related to an accessory or attachment on the camera. First, let's test to see if using a different memory card will resolve this issue. Prior to taking photos on a different card, please format it within the camera. Please note that formatting a card will erase all data from the card. In case this works, then it tells us that the prior memory card may have been malfunctioning which causes the camera to lock up.
If the camera continues to have this blackout issue when using another card, then see if you can test a different lens with the camera. Please also clean the contacts with the current lens you're using to ensure that there is proper communication between the camera and the lens. You may use a dry microfiber cloth to wipe the lens contacts.
I would also suggest disconnecting or removing any other attachment that is attached to the camera to see if an accessory was the cause of this issue. If the issue persists, then we would suggest on sending the camera to our facility for repair.
Items purchased directly from Canon USA or from an Authorized Canon Dealer do include a one-year warranty if the item was purchased less than a year ago. You may view a list of Authorized Canon Dealers by clicking on the following link. I would recommend including a copy of your Proof of Purchase when sending in your item for the facility to review for any in-warranty service or repair.
https://www.usa.canon.com/internet/portal/us/home/contactus/where-to-buy/authorized-dealers
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
