EOS R5 - Focus Jumping
spvsandy
Conon focus jumping around 10% of time  Setting while doing dance with students doing alot of leaps therefore the settings.  Any help with this
Canon R5 Firmare 2.1.0
Dual pixel = disable, Touch control = disable, Shutter mechanical, Focus bracketing Disable
Camera Focus settings
Servo Af
Method=Face
Subject = people
Eye detect = enable
Continuous = disable
Touch =- disable
Af assist beam = off
Servo 3 = 3 instant on subjects
Switch tracking subject initial = 1
Af pt. set = box dot in middle
Auto = Auto
Sensitivity Af point = 0
af 1 setting at face + tracking
initial point set to #2# AF pt set for Various zones
Going to reset to Auto and test tomorrow
Thanks
8 REPLIES 8
March411
You don't mention the Lens(s). Is it and RF and are you having issues with more than one lens?
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Lens is rf 24-105
That’s only rf I have
Thanks
March411
Settings at first glance appear OK but I'll have to look at how I set mine up tomorrow. I use dual back button focus and I want to give you the exact settings. And sorry but I have to ask, that lens has a on/off switch for AF....on?
Marc
Windy City
Personal Gallery
p4pictures
Can you confirm two settings on your camera?
  • AF method from the AF1 menu
  • Initial Servo AF pt for "face + tracking" from AF5
The EOS R5 (original version) can only do face tracking when the AF method is set to Face + tracking, or one of the three Zone AF methods. In the case of the Zone AF methods, it only tracks inside the Zone and will not follow a subject outside the zone boundary.
The setting for Initial AF pt set for "face + tracking" is by default set to AUTO, and with this setup there is no AF point seen on the screen until the camera focuses, at which point it will look for a face in the frame. Your scene with a single person is exactly when I would use AUTO for this setting. If you choose one of the other two options then you get an AF frame that can be moved, it's helpful to "select" a specific subject in a group while using the Face + tracking AF method.
Brian
Thanks
spvsandy
Thanks for fix  Now a heat problem while doing stills
