02-03-2024
06:50 PM
09:01 AM
Hi, just testing out my new camera.
I just returned from playing pickleball with some friends. We played three games and I attempted to record all three games to a 64GB SD card (200MB/s). I stopped recording between each game. The camera created three associated files, but the files are practically empty except for the thumbnails.
The first one is 3 seconds long, at about 50MB (I'm recording at 4k, 29fps) and the other two are 0B filesize. But somehow the thumbnails are there...
Anyway, from some back of the envelope calculations, it looks like the SD card should have been able to fit all three games on there. One thing I did notice is that when I plugged the camera into my PC, the OS showed the card was about 50% full, even though it only had a couple GB worth of files on it (There were a couple other very small video clips of me basically just testing the record functionality for a minute or two). I copied everything the OS recognized over to my storage drive, and reformatted the card using the camera, so if there were some hidden data I wouldn't be able to recover it, and anyway the clips are not that important - I'm just testing the video record function out.
Couple other things, it was about 68 degrees F outside, but I placed the camera in the shade. And I was kinda keeping my eye on it the whole time to make sure nobody knocked over the tripod, etc.
Any ideas what happened with the these clips? This is the first time I tried to use it to record any extended length of video outside, and I'm a computer scientist but I can't really think of any reason it would've generated three empty files.
02-04-2024 11:40 PM - edited 02-04-2024 11:42 PM
Eyyy! I did not know that, and just tested it out. It was able to transfer the video, thank you, thank you thank you!
Although it seems to be using the Wifi to do it which seems a bit inefficient compared to just plugging it in and transferring over a wired connection but, whatever works. Also it looks like it automatically organizes uploads by date which will be helpful.
I have a bit of background in operating systems, so this is just an educated guess, but the metadata and video data are probably two completely separate "blocks" on the cameras file system (which I just learned is "DCF" - Design rule for Camera File system). It sounds like some kind of miscommunication where the computer was able to read the metadata, but not the actual video data itself. The thumbnail is probably stored with the metadata, separately from the video data - and very likely generated by the camera automatically. (Come to think of it, I assume that's what is displayed when you are reviewing thumbnails on the camera itself)
02-05-2024 08:40 AM
elijahrockers,
I use EOS Utlity in a wired mode all the time.
Just run the cable from the USB port on the camera to a USB port on your computer. I always open the program on the computer first. After it loads, I then turn on my camera. The connection is instantaneous.
To ensure that there is no problem with the cable, I use the IFC-600PCU cable from Canon.
Steve Thomas
02-05-2024 09:45 AM
elijahrockers,
I just remembered that I have a micro USB-B port on my camera.
You may have a different USB port on your camera. Check your manual for the proper cable to use.
Steve Thomas
03-07-2024 08:37 AM
can you drop a link to the eos utility? the webcam utility is the only one i can find.
03-07-2024 08:45 AM
found the utility, didnt solve my problem
the eos utility does not even show the videos. but they will play on the camera. and if i try to strip them directly with a file explorer, the videos are presend, but listed with 0bytes, and only a thumbnail. video wont play on computer
03-09-2024 09:52 PM
I noticed this and have been using the eos utility or the card reader to copy those kind of videos, that is, larger files. Small size video size have no problem getting copied over the usb cable connected directly from the camera to the PC but the larger ones get copied with a 0byte in size.
Does any one know a way to recover the video? Before I discovered it I had copied an important video and formatted the card, I am left with the 0 byte video.
12-29-2024 10:23 PM
Hey elijahrockers, did you ever find the solution?
I'm having this same issue
