EOS R5 won't focus, black screen in EOS Utility
CCRider
Hi:
I am using EOS Utility 3 to control the R5 through USB-C.
I have an external studio strobe attached. When in Manual Mode, the camera is incapable of focusing and screen goes black. In any other mode the camera is able to autofocus but does not shoot with flash only. The shutter is in full mechanical mode.
Any suggestions?
Thanks
C
p4pictures
You need to disable exposure simulation to be able to see when using flash.
Say you set the camera to 1/125s and f/8 at ISO 100. If exposure simulation is enabled, which it is by default, then most studios will be too dark to see anything but a black frame since the camera is not able to simulate the exposure with the flash as it's not fired before the exposure is made.
Set Exposure simulation to disable and you will be able to focus and see the subject.
Brian
2 REPLIES 2
p4pictures
Brian
p4pictures...thanks very much for the prompt response. enjoy your holidays.
Clint Clemens
