12-03-2023 09:12 PM - edited 12-03-2023 09:16 PM
I damage the eyecup structure that holds it with the body when I was travelling. The structure with the screw was broken and the eyecup is not firm anymore. Is this possible to be repaired? 😞
12-03-2023 10:29 PM - edited 12-03-2023 10:35 PM
Sorry this has happened. This appears repairable, but its not going to be inexpensive. This portion of the eyepiece is part of the top assembly. If you have a Carepak thats a plus. Next step, register your product in MyCanon, open a support case and you'll get an estimated cost for repair. The camera will need to be inspected.
12-03-2023 10:48 PM
Thank you very much for your reply. I will contact Canon support and see how it goes.
12-04-2023 10:06 AM - edited 12-04-2023 10:07 AM
Hope it works out. Here is a better angle. Following the lines of the body, its not the top, but the back of the body that will need to be replaced.
12-04-2023 10:16 AM
I now understand. Thank you very much!
