10-13-2025
09:42 AM
09:43 AM
James_C
I've been struggling with shooting and rating images on the fly. Here's what I want to be able to do:
1. Preview images immediately after capturing and then rank or favorite the frames I want save for later.
2. Quickly view only the ranked pics on my camera, filtering out all the others.
3. Convert those RAWs to jpgs to send out immediately.
I know how to rate images, and when I bring them into Photo Mechanic sorting by rank is easy. But I'd like to be able to sort/filter while viewing on my camera in the field.
10-13-2025 11:09 AM
Yes you can apply a filter to images on the camera and there are a few choices of how to do that.
10-13-2025 02:57 PM
Carl,
With respect to your third question about converting RAW photos to jpgs, on my camera at least, (a T8i), you can convert RAW's to jpgs this way:.
1) Go into your Image Playbacks and hit the Menu button.. Go to the second page.On my camera, it's blue with a little right-facing arrow.
2) On your second Menu tab, there is a setting for RAW Image Processing.
3) Hit that and select the images you want to process. At that point, you can select one image, or a range of images by hitting your Set button.
On my camera, once you have selected the image or images you want to process, you hit the Q button.
4) On my camera, you are offered a choice of using the shot settings you have or customizing various settings like brightness or white balance, etc.
If you choose shot settings, it will immediately convert that image to a jpg which you can save or not as a new file.
Steve Thomas
10-13-2025 11:09 AM
10-13-2025 02:57 PM
Carl,
Steve Thomas
