01-10-2023
04:36 PM
08:08 AM
just purchased a EOS R5, Is it adviseable to remove the battery when the camera will be in extended storage ? also, do I need to do all firmware up dates, even if they are for a feature that I do not use ?
01-10-2023 06:21 PM
Li-Ion should be stored 40-50% in a cool and dry place if you don't use camera for a while.
01-10-2023 07:33 PM
ideally. leaving in the camera will have a slight draw as the top LCD still gets powered. I have the R5 grip and I just remove the grip (with batteries still in grip).
01-11-2023 01:42 AM - edited 01-11-2023 11:05 PM
It is always a good practice to remove the batteries from your camera when it is not being used. If you leave the batteries in your cameras unused. Tgr Batteries will get discharged automatically, not only that if if finds little moisture not only your batteries will get rusted. Your camera will be adversely affected which may lead to failure of internal chios(IC). Remember that rechargeable batteries grow less powerful the more you use them. It's advisable to keep a spare at hand. HEB Partner
01-11-2023 04:50 AM - edited 01-11-2023 01:04 PM
I find that the R5 in particular runs batteries down fairly quickly if you're not using it, like for days to weeks; so I take them out.
As for firmware updates -- you don't ever need to apply a firmware update. Personally I prefer to keep all my kit up to date with firmware, although it's much less of a priority if I don't see anything interesting in the update description. However:
So... I guess I would recommend waiting a little, after new firmware comes out, to see if the eager beavers (like me) report any issues. But then, yes, my approach would be to update.
01-11-2023 09:38 AM
@Ettannen,
To add, I'm in agreement with the guys regarding removing batteries and storage when not using the camera for extended periods. Better for the camera and you.
Firmware:
At this point the latest available FW for the R5 includes some pretty significant feature and performance updates.
If your camera is using FW v1.5.2 or earlier, I would upgrade to v1.6.0 (at minimum) or v1.7.0
The new additions in v1.6.0 were significant. You can go straight to v1.7.0 as well, regardless of the version you are running now.
01-11-2023 10:30 AM
Simple answer, yes to number one and no to number two.
