EOS R5 Artifact in Image
musicmaiden
I just got a refurbished R5 and when taking it out on the second day, I got this pink band on a couple of images. What could cause that band?
13 REPLIES 13
musicmaiden
Thank you Ricky!! Since I had issues with the first refurb R5, I was a bit concerned about now having to deal with a return because of a bad sensor until I came across the Pink LR Preview and then a "corrected" image when pulling it up.  It sure sounds good to hear from an expert that it seems to be some sort of file error. As you suggested, I will set both captures to CR3 or CRaw and to separate cards to see if it repeats.  Appreciate your time and expertise!
Karin
Kvbarkley, I will extract the JPEG Preview of the Raw file in PhotoMechanic and see what it shows to confirm it! Thanks for the tip!   I can deal with a corrupt preview, as long as it is not the sensor !
Addendum:  I extracted the JPEG of the RAW file in Photomechanic and it showed the same banding, so a corrupt embedded preview! Thank you!
Peter
Nothing strange with the raw file more than that one of the embedded JPEG files is damaged, as you already know. 1620x1080px JPEG and 160x120px JPEG are good.
Extract them all with Exiftool
exiftool -a -b -W %d%f_%t%-c.%s -preview:all YourFile.CR3
Comparing the embedded JPEG with the raw file:
Full size embedded JPEGFull size embedded JPEG
Raw file with no demosaicing and no cropping of the left borderRaw file with no demosaicing and no cropping of the left border
A brighter version of the raw file with no demosaicing and no cropping of the left border. Nothing strange in the masked pixels either.A brighter version of the raw file with no demosaicing and no cropping of the left border. Nothing strange in the masked pixels either.
musicmaiden
what a relief! thanks for the time and demonstration on what you did to check, Peter!!!
