12-27-2023
03:41 PM
03:44 PM
Attempting to update firmware 1.30 to 1.40 on EOS R10 but "OK" is greyed out so cannot initiate the install. Have successfully applied other updates so I know the correct procedure. Any help is appreciated.
12-27-2023 04:46 PM
Did you try selecting the gray OK? I noticed on my last R6 and R6 II f/w updates, OK was grey, but it was still selectable and started the update.
Newton
12-27-2023 05:38 PM
Yes I did press it several times and nothing happened. Went through the procedure 3 times with same result. But maybe I did not wait long enough. Will try again with more patience. Thank u for response.
12-27-2023 05:46 PM
Your suggestion worked. Thank u very much.
05-15-2024 11:58 AM
Worked for me too, thanks for that
