EOS R10 questions about Wi-Fi connectivity and metering
thetoxicmud
Enthusiast
I’m almost finished reading manual and asking these amateur questions, I have hit two settings that puzzle me. One not so much important, but manual states that the camera should maintain connection with WiFi even when it’s off, well my r10 does not do that and I was wondering if I’m doing something wrong, is there some malfunction? As soon as the screen goes dark the connection to WiFi and app is lost, even without flipping switch  to off. Camera maintains connection with Bluetooth but lose connection to WiFi very easily when screen goes off.
similarly manual states camera can send images to phone via Bluetooth, but this is not possible and this error appears if not paired with WiFi, unless some changes with firmware update were introduced my camera is it doing these things.
Also I came across this feature , speee from metering ISOauto
both settings in av mode I tried behave in same way, when I press shutter button it locks iso and restores auto after releasing, in both setting instances. I’ll be very grateful for explanation of this setting .
2 REPLIES 2
jrhoffman75
You might want to be sure your product is registered and contact Canon support directly.
Canon Support for EOS R10 | Canon U.S.A., Inc.
This forum is a great resource, but getting a resolution requires 1. someone with your device and 2. that person(s) knowing the response.
Could be a longer wait than contacting Canon directly.
Thank you, I wanted to contact canon after confirming if this is my error or gear malfunction.
Avatar
