12-26-2024
04:25 PM
08:18 AM
James_C
Firstly, let me describe my issue: I have an R1 and a 600EX II RT flash. When I set everything to manual (shutter speed, aperture, ISO and flash power), it should take photos at the same burst speed regardless of what I'm shooting (some photos would just end up exposed differently). However I'm finding that when my subject would (without flash) be underexposed, the burst speed WITH flash is much lower, despite everything being identically set on manual.
Here's a video example: https://www.youtube.com/watch?v=cH8uXa50IGA
It starts out black (because of exposure simulation, the scene is underexposed without a flash), but as soon as I half-press the shutter, the scene brightens up. The burst that then follows is slower the darker the subject is, even though shutter speed and flash power are identical.
My suspicion is that it has to do with the scene preview exposure behaviour, where it automatically turns off exposure simulation whenever a flash is attached (or whenever metering starts with a flash attached): https://www.youtube.com/watch?v=ZjWVEQbdi40
I suspect it tries to properly expose the scene because there is a flash attached, increasing aperture to f/2.8 (up from f/5.6) and increasing ISO, and then has to swap back to f/5.6 and ISO 200 again for the photo. (And then back and forth again and again in between burst frames??) I cannot think of any other explanation why the burst rate is different with all those settings identical in full manual mode. Burst rate isn't bottlenecked when not using flash, so that rules out processing or card write speed issues.
Has anyone else come across this issue, and is there any possible workaround that does NOT involve taping off contacts and removing the possibility of using E-TTL?
I've read this thread on a related topic, however my use case is different because my flash burst rates are actually significantly reduced because of this issue, whenever relying on flash to fill an underexposed scene.
12-28-2024 02:07 PM
Ambient lighting affects the camera’s metering system. Then you have the buffer too and the flash needing to recharge.
12-27-2024 05:13 AM
The flash will speed up and slow down depending on how hot it is. While your video shows the faster speed working after the previous bursts, I don't know what you were doing before this video. If you had already done a similar test then made the video, it is possible that the Speedlite was "hot" at the start for the first sequence, and therefore could not keep up so slowed the frame rate to allow it to cool down even while working. But by the third set it was cool enough to go faster again.
If you manually raise the camera ISO 1-stop, you can drop the flash power by 1-stop from 1/64 to 1/128 and that might be better for fast bursts.
12-27-2024 05:47 AM
The flash had been cold for several minutes before that video. It is not related to the flash temperature. It's clear when it overheats: it will hitch slow down to only one or two shots per second, which is very noticeable.
This behavior is not just a one-time occurrence; it is consistently happening in the way that I described, with various (manual) settings. Only when photographing a lit scene is my flash (correctly) the bottleneck for burst rates. When photographing a dark scene, which consistently coincides with the visible disabling of exposure simulation/re-exposing of the viewfinder, the burst rate is significantly lower (down to around 6fps). The order doesn't matter.
It happens the same way at minimum flash power (but 1/64 is already pretty low).
I'm actually curious whether other cameras that have the same flash / exposure compensation behavior (like the R5, or R5 Mark II) can reproduce this issue as well, or whether it's specific to the R1.
Try these steps:
Is your burst rate the same in all 3 situations? Manual exposure and flash power settings are identical, so the burst rates SHOULD be identical.
12-28-2024 01:37 PM
Only three cameras can shoot with flash and electronic shutter mode, EOS R3, EOS R5 Mark II and EOS R1, all other EOS R-series cameras will not fire the flash in electronic shutter mode. They will in first curtain electronic and mechanical shutter mode. So only those three models are suitable to test. My EOS R6 Mark II will shoot at 40fps in electronic shutter, but is limited to 12fps with first curtain electronic or mechanical.
12-28-2024 01:54 PM
That may have been true before the Canon R1 came out. The R1 is their new flagship camera, and I can confirm (and you can see in the video I linked) that the flash DOES fire in electronic shutter mode. It even has a flash sync speed of up to 1/400th of a second in electronic shutter, full frame mode.
12-30-2024 06:41 AM
As an update, I have not found a fix for this behavior (though still suspect the viewfinder preview to be related to the cause); burst rates are still greatly reduced when shooting dark subjects with flash enabled, even if all settings are dialed in manually and autofocus is on manual or single shot mode.
My 'workaround' has been the in-camera "focus stacking" feature. Using this, I need to pre-define the amount of shots to take (for example, 60 shots), and then press the shutter once to start off a burst. This burst will happen at maximum possible burst rate, so limited only by the flash (and it is obviously MUCH faster than 6fps, even when shooting dark subjects).
The only downside to using this workaround is that I have to pre-determine the amount of shots to take, and that I cannot configure a slightly lower burst rate for a more consistent burst without flash slowdowns halfway in (due to overheating or flash cycle times). In focus stacking mode, it will always fire at max burst rate regardless of my burst settings.
However, I've been able to get some nice stacks this way without being restricted to 6fps. These are two of my first ever (handheld) focus stacking images taken yesterday; I'm quite pleased. Stacking was done using Zerene Stacker.
12-30-2024 05:30 PM
Greetings karmlol,
I am sorry to hear that your camera and flash are having a performance issue during certain shooting environments. Sometimes things can be more efficiently resolved by discussing the issue in real time with a live agent. Given the nature of this particular issue, I would recommend calling our tech support department by phone. Technical support can be reached at 1-800-652-2666 between Monday and Friday from 9:00 am to 6:00 pm EST.
01-14-2025 06:16 AM
I have contacted my local Canon support. The product specialist was able to reproduce the issue in their own environment and it has been escalated to a higher level in Canon Europe. I hope it will eventually find its way to the developers and a firmware update.
01-14-2025 06:19 AM
Thanks for the update.
01-23-2025 03:27 AM - edited 01-23-2025 03:28 AM
Final update (for now): Canon got back to me and said it's a hardware limitation, but didn't fully explain why.
The workarounds they offered were to either use the mechanical or second curtain electronic shutter, where they say the issue doesn't occur. I will give those a try at a later point.
I did request a change to fix this issue for electronic shutter mode if autofocus mode is set to either single shot or manual. In those cases I feel the re-exposure in between shots should not be needed and could be skipped in favor of the faster burst rate.
I was cautioned that these requests end up with the developers with several international layers in between, and that there's no guarantee they will be fixed and end up in a firmware update, or in what way (paid upgrade or not). But one can hope.
