EOS R draining battery overnight
zax3303
Hi all, my R is draining battery overnight -30%...gps is off, wifi is off, camera is off! Any ideas? Using original LP-E6N battery.
13 REPLIES 13
Tindo2
I have this problem on an EOS R but only when a Laowa 100mm 2x macro (auto aperture) is left attached. The battery flattens in a few days to point the camera will not switch on, degrading the battery.  I have not sorted whether it is the lens, camera or the way the are communicating which is the problem.
MrSP
My 2c
- Canon R is very power hungry, 150 photos, with a bit of fiddling around, will do that.
- the top screen can be turned off as well ( when the dial is OFF ) - I decided to keep it on
- if you have a short in the camera, maybe it should also get hot ?
Hop Hop
Sir,
It is Laowa 100mm Canon problem NOT your camera problem
I have 100% exactly same issue
I use Laowa 100mm canon on my 5D mk3
It drain a fully charged battery from 100 to 0 in 3 days
(  camera is POWER OFF )
Laowa still cannot tell me how to solve this problem..
If you have any update from Laowa USA, please let me know
Thanks!
Sir,
Thanks!
Friends and Family
