EOS R3 battery drain issue
AAA-J
Hello,
I have reset my camera settings, lens is off, sd cards slot empty, no accessory attached.
Official canon battery. I have a moderate performance and a excellent one.
The battery would drain after 12hrs it be at 95%, and 24 hrs @ 88%. These are rough numbers.
I'm concerned because within a week of having the camera off, never turned on, with a freshly charged battery inserted the camera battery would be drained close to 0-20%.
EOS R3 #firmware 1.7.1
2 REPLIES 2
Waddizzle
Welcome to the Community. Sorry to hear about your experience:
It sounds like you have done your homework looking into the issue:  Here’s a checklist, most of which you have already done. In no particular order.
  • Not switching the camera off when not in use.
  • Using third party accessories, lens mount adapters in particular.
  • Not disabling wireless communications when not in use, particularly GPS.
  • Leaving cabling connected to the camera when not in use.
I am sure there could be other causes I haven’t thought of today.  You made no mention about wireless communications, so I assume that you are not using it.
If the issue persists, call Canon Support.
Good catch, I have all wireless communications off, no cables attached, no third party accessory, always turn my camera off when not in use 99% (to cover the 1% of possibility not turning off when not in use, I've been doing tests with fully charged batteries with different performance), let me edit my post.
Friends and Family
