EOS R busy/saving during Tether
vegaroyfoss
Hi All
I have a strange situation where sometimes when I am connected to Lightroom or Capture One tethering a shoot, the Camera suddenly stops responding and I cannot take any more pictures. The light indicating activity/saving just above the delete button keeps flashing forever.  No other indiation what is going on. If I turn the camera OFF, I get the attached message on the screen:
It might be 1 image, 3 or 10 and more. I have been struggelig to understand why this is happening. The only way to stop it is to pull out the USB cable
I also tried today into Lightroom, when I got this error, using NO SDcard at all...still it happened
Anyone has encountered the same, and or know what the issue is?
12 REPLIES 12
davidburns
Thanks Ralphsomma, I just migrated back to a canon from sony (started with canon 5dmk2) and had the busy issue while shooting tethered on the last 2 shoots.
Removing the card works!! you saved me 😁
am shooting on R5 3m usb-c to usb-c tether tools. shooting to M1 macbook air 12.3.1
That never actually halp for me as you see in my original post. BesidesI prefer to shoot onto card AND tether at the same time
But what DID help was to simply buy a powered USB hub to place in between my laptop and camera. Since then no disconnection from Lightroom OR an busy message on the camera.
As you said, there seems to be some laptops which are not outputting enough power via USB, and that is a purposely added limitation from HP (in my case) I assume to help in other areas
Might be soething to think of for people who by a laptop specially for tethering - test it first
I didn't mention it vegaroyfoss, but I also tried a powered USB hub and had no success. Tether Tools suggested it but said I should remove all other components first. I didn't do that as it would not be a workable solution for me. Did you?
I too would rather have memory cards in camera when shooting tethered and will try the Tether Tools boost controller when it becomes available.
